I have been trying to create vault from this irregular plan and I want it to have 4 exits where the straight line is. I have tried doing it on grasshopper and it doesn’t seem to do them job. I tried downloading Rhinovault as a plugin which also doesnt seem to open.
outline your footprint make it rather roundish which works better for the later steps you can have straight parts either just dont make hard edges, extrude the outline. add a few dots within the area to gain control over the shape for the next step. now use patch with option tangency, use the extrusion edge as input. if you turn history on before patch you can lift and drop or move the points to change the surface.
finally extrude the the planar curves or use the gumball to directly cut the surface with them.
