I’m tryihg to produce some parts and even though the curves are copies - mirrored I get different resulst from the same procedure. And sometimes no result at all.
NETWORK.3dm (249.6 KB)
I see that - - the curves are not all lined up very cleanly - check closely how they come together at the tip.
The network curves seems to work other wise withoug having every curve make full contact. In any case here’s a vid
Update - move control points to touch lines and got a result. I’ve been using the network tool for some time now and came to see it worked with greater tolerance - expesially with a knife handle.
