Irregular mesh subdivision
Hi everyone,
I’m trying to make an irregular mesh subdivision of a complex surface.
Searching to look like this rabbit :
But on this kind of surface and WITHOUT Weaverbird (never succeed the instalation)
I tried lunchbox panelization but they all regular, i want planar triangle but with irregular lenght
If you have a clue, your welcome, here the definition with internalized data…
irregular_mesh_subd.gh (13.3 KB)
Thanks a lot !
Triremesh with low iteration is not too regular
Or you can use this trick, has you have a surface, make a first mesh on this surface, use the uv coordinate to make a mesh on XY plane, suppress some points then Use Delaunay Mesh in XY plane and then go to 3D surface.
Here some variations
irregular_mesh_subd_LD.gh (17.1 KB)
Or you can pouplate randomly your surface, I used a component from Nautilus that is far less regular than populate geometry from Grasshopper
irregular_mesh_subd_LD2.gh (15.7 KB)
irregular_mesh_subd_LD3.gh (16.5 KB)
Hi @laurent_delrieu,
Thanks for you answer ! This is exactly what I was looking for !
Have a good day !
