In iRhino 3D, is there a way to select all objects in a layer, as per Rhino 3D? I have searched, but cannot find it. As an example of the use, I would like to select floor bearers and joists so that they show with the normal yellow edge lines through the rendered perspective image in orbit. This is a great way of seeing the fit of buried objects within a structure. It would probably require a Select column on the Layers list.
Regards, Garry.
