IPlane as stand-alone command can be dangerous
IPlane can be dangerous when used as a stand-alone command to create an object. (Okay when used within another command.)
When used stand-alone to create an object Iplanet does not create an “infinite” plane as the name implies not “pseudo infinite” plane as stated by the Help enntry. Instead it creates a regular “plane object” which is a bit bigger than the objects currently visible, emphasis on “currently visible”. It does not take into account objects which are hidden or on hidden layers.
A user can use IPlane to create what they believe to be effectively an “infinite plane” with the desired orientation for later use. But if all the objects that plane will be used with are either not visible or not existing when it was created, then the plane may not be big enough to interact with those objects as if infinite.
Example: I need large plane to use for trimming objects including some which are not visible or which do not yet exist. I have some objects not visible. I use IPlane to create the plane. Later, I use Trim with what I believe to be effectively an infinite plane and the objects are not trimmed. I wrongly assume that an infiinit plane with that orieintation does not intersect the objects.
Good to know. I assumed “i” was for interactive plane, not infinite…
