Ipad pro m1 and rhino
there will be the posibility to use rhino on ipad pro M1???
or never mind ???
No.
iPads run iOS, not macOS so not possible.
N°1
N°2
for a less cumbersome method to use rhino on the ipad you might look into duet using the ipad as a secondary screen, that naturally requires a different device having rhino installed.
if you choose path nr1 pls let us know if that worked.
