seth
February 28, 2014, 10:26pm
1
Very weird, I have two meshes that refuse to show up at print time. They will both render just fine, but when I go to print, they won’t show up no matter whether I have wireframe, shaded or rendered viewports. You can see this in the attached image. Any ideas?
-Seth
pascal
(Pascal Golay)
February 28, 2014, 10:29pm
2
Hi Seth- what does the Check command tell you about the mesh? You might try RebuildMesh and see if that sorts it out.
seth
February 28, 2014, 10:38pm
3
Hi Pascal,
I did try rebuildMesh and so far no change. You can see the checkMesh info for the figure attached below:
pascal
(Pascal Golay)
February 28, 2014, 10:48pm
4
Hi Seth- please ssend us that mesh via tech@mcneel.com , I’ll take a look or send it to a bigger brain.
thanks,
seth
February 28, 2014, 10:49pm
5
Will do. Thanks for taking the time.
-Seth
pascal
(Pascal Golay)
February 28, 2014, 11:09pm
6
Hi Seth- the mesh has its Print Width, in object Properties, set to No Print.
seth
March 1, 2014, 2:19am
7
Geez,… So embarrassing! Thanks for taking a look, sorry to bug you guys with this.
-Seth
