Invisible mesh faces
I have imported some meshes from SKP and the visualization is a bit messy as you can see in the image in attachment.
Even if some surfaces are there they are displayed as invisible(volume top).
The problem seems to be fixed when I explode the whole mesh (volume bottom).
What am I doing wrong?
This looks like back facing issue of some sort, can you post a small file and your Systeminfo (via Rhino command line) Thanks
Rhino 8 SR2 2023-12-12 (Rhino 8, 8.2.23346.13001, Git hash:master @ dbefe46c12cda06610a9ab683a211aa3d16f0030)
License type: Evaluation, build 2023-12-12
License details: Stand-Alone
Expires on: 2024-03-18
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 970 (NVidia) Memory: 4GB, Driver date: 5-24-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 535.98
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-24-2023
Driver Version: 31.0.15.3598
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.2.23346.13001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.2.23346.13001
STAIRS.3dm (113.7 KB)
the backface setting is already on ‘use front face…’ but still…
The backfaces is a thing, but in the one area it looks more to do with the Mesh.
Can you provide the .skp to import as well, maybe we can deal with it there.
TEST SKP.skp (611.3 KB)
I also would like to point out that this behaviour happen with almost all SKP files…
Importing with these settings creates proper mesh faces
you can run unifymeshnormals to fix any issues with normal direction as well.
mine opened bad like yours did…
exploding the blocks and then exploding the meshes was the 1st step. run unifymeshnormals, then join each mesh individually was the next step.
polygon files are pretty simple to diagnose…but the process can be tedious.
they are either unjoined with naked edges (use showedges)
joined with screwed up normals (use unifymeshnormals)
or have duplicated faces joined on top of each other (explode and use seldup to find them)
see this video on other mesh repair ideas-
Thanks!
