I’ve investigated this further and managed to isolate the issue.
The problem appears to be specific to multilayer walls.
In Top – Level 01, with Level 00 visibility turned off:
Single-layer walls from Level 00 are correctly hidden.
Multilayer walls from Level 00 remain partially visible in Wireframe mode, even though their level is turned off.
These walls can also be selected using window selection.
In Hidden mode, the unwanted geometry is no longer displayed, but the selection issue remains.
The attached screenshots show the difference between the Level 01 and Level 00 floor plans.
So this appears to be a visibility and selection issue affecting multilayer walls, rather than a general floor-level selection problem.
I hope this helps narrow down the cause.
Update – Further testing
The issue is not specific to multilayer walls. It appears to depend on the wall geometry relative to the upper floor plan.
Setting the walls’ Top Elevation Offset so that they end below the upper floor level prevents unwanted selection, making the workflow usable.
However, the underlying issue remains: objects belonging to a hidden level should not be selectable, regardless of their geometric extent.
System info
Rhino 8 SR36 2026-10-20 (Rhino 8, 8.36.26293.11001, Git hash:master @ 824eaa40694d0076394d36eac84fb3109a9f5f62)
License type: Commercial, build 2026-10-20
License details: Cloud Zoo
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 15GB)
.NET 10.0.9
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-22-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.88
Integrated accelerated graphics device with 4 adapter port(s)
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-22-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.88
Secondary graphics devices.
AMD Radeon 780M Graphics (AMD) Memory: 1GB, Driver date: 12-5-2023 (M-D-Y).
Integrated accelerated graphics device with 10 adapter port(s)
- This device is not being used
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-22-2026
Driver Version: 32.0.16.1088
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.36.26293.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.36.26293.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.36.26293.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.36.26293.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.36.26293.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.36.26293.11001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.36.26293.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.36.26293.11001
