Invisibe make2d results in Rhino7 for Mac on M1 MacBook Pro
I’ve downgraded file to rhino 6, and opened in rhino 6 and it was ok.
Hello - can you please post that file? or send to tech@mcneel.com, with a link back to this topic in your comments.
uploaded
Hello - the pages look like this on Windows, is that what you expect to see? :
I’ll check Mac.
Also OK, but not an M1 - can you please run SystemInfo
in Rhino and copy/paste the results here?
yes, it’s what I expect, but there is no make2d result, only dimensions and regular objects
Rhino 7 SR5 2021-4-10 (Rhino 7, 7.5.21100.03002, Git hash:master @ 2cd158094b595f6400479d7cbe511454b6149527)
License type: Evaluation, build 2021-04-10
License details: Stand-Alone
Expires on: 2021-07-12
Apple Intel 64-bit macOS Version 11.3.1 (Build 20E241) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro17,1
Language: en
Apple M1 (OpenGL ver:4.1 Metal - 71.5.9)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple M1
Displays: Unknown (298dpi 2x)
Graphics processors
Apple M1
Color LCD (1680 x 1050 @ 60.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Apple/usr/libexec/oah/runtime
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/Users/czarek/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.2.rhp/libDLRhinoNative.dylib
/Users/czarek/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.2.rhp/libPolygonCruncherSDK.dylib
/Users/czarek/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.2.rhp/libSyncData.dylib
/Users/czarek/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.2.rhp/libomp.dylib
/Users/czarek/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.2.rhp/libc++.1.dylib
/Users/czarek/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.2.rhp “Twinmotion Direct Link 2020” 1.0.6.0
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.5.21100.3002
Hello- if you draw a new curve in the model space, does that show in the layout? Does the detail’s current display mode have curve drawing enabled?
yep… curves were turned off
thank you foru your time
Is there any active clipping plane in your project file ?
