Inverse of Unwrap
Here I have a plate that is intended to form a circle. I laid out from 3d locations on s cylinder and used UNWRAP to find the plate cutting
Is there anyway to do a reverse of UNWRAP to map the lines in 2D when the place is bent into a circle?
Hello- you can Flow the surface from a line to a circle of the correct diameter.
Does flow work on a closed curve?
Any reason not to try it yourself?
I tried and it did not seem to work. I ended up splitting everything in half.
