Introducing the first Rhino.Inside.Revit GPT Assistant
We are excited to publish the first Rhino.Inside.Revit GPT Assistant.
Rhino.Inside.Revit is powerful, but many users face the same challenges every day:
• Does an official component exist for this task?
• Where can I find it and what inputs does it really require?
• Why does my Grasshopper workflow not behave as expected?
• When should I use Node In Code versus Python?
• Which references, transactions, and geometry conversions are correct?
This GPT assistant is created to help answer those questions.
It helps you identify the correct official components, understand their inputs and behavior, and generate structured Node In Code or Python scripts that follow Rhino.Inside.Revit best practices.
The goal is simple:
to reduce guesswork and help users build correct, predictable workflows faster.
If you are learning Rhino.Inside.Revit or exploring automation workflows, this assistant is designed for you.
Feedback and suggestions are welcome.
