Hi all,
I am using Intralattice to populate a volume defined by two custom surfaces that I have generated from an existing stl mesh with a custom unit cell that I have defined in Rhino. Right now the meshes that define my two surfaces and my unit cell are in different files. I want to know how I can use multiple Rhino files in Grasshopper. I would like to use my 1 file in Rhino with my volume defining meshes and my unit cell defining mesh to create a new file of my unit cell populating my custom defined volume. I am using set curves to define my unit cell in Intralattice, and set meshes to set my volume. Furthermore, whenever I close and reopen the program, I need to reset my curves and volumes each time. Is there a way to tell Grasshopper what curves or meshes I want to set each time and have that save after I close the program?
Any help is appreciated, thank you
