Hi All,
Very new to grasshopper, i’m trying to find the Interval battery that used to be in the old Scaler tab?
can someone direct me?
Also, i’m running into this issue a lot so is there a link where i can download previous versions of Grasshopper for Rhino 5?
A
Nevermind, just found it under domain
There are two parts of grasshopper. Parameters and Components. Parameters hold geometry, components do things. What you call as battery is called a component. Just for future in case you have more questions and someone does not understand what you mean so you know the terminology. Grasshopper Object Types | The Grasshopper Primer (EN)
Thank you Michael. Good to know.
I’m also finding that my grasshopper work is displaying in every viewport but my perspective view-any thoughts?
Are you using Rhino 6 and is your perspective view by any chance set to rendered display mode. Rendered in Rhino 6 won’t display gh unless it has a material.
