Intersection
I have a question. I can’t doing the intersection of the two pipe. Could you please help me to do this an explain how can I do?
best regards,
Nicolas
test.3dm (2.7 MB)
More explanation… like this (the 3th drawing) , but with a perfect intersection
test.3dm (2.8 MB)
Hi Nicholas - what command are you asking about, Intersect or BooleanIntersect or? Both of these seem to work OK here.
hello,
The preview on my Mac is so bad (a lot of imperfections), so it is not possible to verify if the intersection is good or not. If someone to help me?
Thanks a lot,
Nicolas
Hi Nicolas -
It’s not clear to me what you are trying to do and that picture doesn’t look like any of the files that you have provided. I’d run the Intersect command and check the resulting curve to see if the intersection is “good” or not.
how can we do to have a better preview to see if the intersection is good or not good?
best regards,
Hi Nicholas - run the Intersect command.
thanks.it was what I was searching. But have you a tips for a better screen view? with more details?
Nicolas
thanks a lot :wink:
Nicolas
adjust the rendermesh that will get rid of that jagged visual imperfections, it will not help you getting better intersections though at least not in that regards.
If you are looking for better shaded display, see
https://wiki.mcneel.com/rhino/meshfaq
