Intersection Issue
I have a case of intersection that fails, if you open the file you will see that rebuilding the green surface lets you obtain the intersection, but with the origina degree you can’t.
I need the intersection between green and blue objects.
Intersection issues.rar (372.5 KB)
Hi Joaquin- I see that, thanks, I’ll get it on the bug pile. Just fyi, if you InsertKnot, Automatic, a few times in either the blue or the green surfaces, to make them a little denser, Intersect also works- the advantage is then the shapes remain identical, not the case with Rebuild.
Bug item (not visible to the public, yet)
http://mcneel.myjetbrains.com/youtrack/issue/RH-26945
Thanks Pascal, you allways have something new to share :slight_smile:
