I have been running into intersection problems in multiple computers after restarts and reinstalls. Not sure if that is an isolated problem or something about SR12.
Hi Raul -
That sounds like an issue with V-Ray. Does to work when you disable V-Ray in the plug-in manager and then restart Rhino? If so, please let Chaos Group know about this issue.
That’s true. I will contact chaos group.
I’ve been getting this issue too.
@wim Is this confirmed Vray issue?
And how is it Vray if it’s the intersection command?
@raul Did you get a reply from chaos group about this?
Chaos: "*We’re aware of this issue and it is logged under VRW-3487 in our internal bug-tracking system. *
Our developers are currently actively working on resolving this. We will let you know once things are fixed and a stable build or a hotfix is available. "
