I got an error with this simple code -
def test():
box = AddBrepBox(-5000, -5000, 0, 10000, 10000, 10000)
if box is None: return
planesrf = rs.AddPlaneSurface( rs.WorldXYPlane(), 100000.0, 50000.0 )
rs.TransformObjects( planesrf, rs.XformTranslation([-10000,-25000,1000]), False )
curves = rs.IntersectBreps( box, planesrf )
The error msg I got is -
unable to convert Success into Brep geometry
Any ideas? Many thanks for help!
–Max
dale
(Dale Fugier)
2
Your code is incomplete - where is your AddBrepBox
function?
Please post complete code that we can test. You can upload Python files. When editing a post, click the “Upload” button.
– Dale
Sorry, here’s the definition of AddBrepBox -
def AddBrepBox(x0, y0, z0, l, w, h):
pt0 = Rhino.Geometry.Point3d(x0, y0, z0)
pt1 = Rhino.Geometry.Point3d(x0+l, y0+w, z0+h)
box = Rhino.Geometry.BoundingBox(pt0, pt1)
brep = box.ToBrep()
rc = Rhino.Commands.Result.Failure
if( scriptcontext.doc.Objects.AddBrep(brep) != System.Guid.Empty ):
rc = Rhino.Commands.Result.Success
scriptcontext.doc.Views.Redraw()
return rc
I found the problem - what AddBrepBox returns is not the object, but a status. Thank you Dale.
