I’m having a hard time to interpolate a curve through points so I could achieve a sort of a “mandala” pattern tree as shown in the image that I’ve modelized by hand in Rhino.
Could someone help me on why the interpolated curve forms a loop?
Here’s my take on scripting the Rhino model you’ve shown. I tried to keep your original script logic, but switched out the circumferential numbers in favor of a graph mapper as I believe it gives a nicer output.
Breps in general slow things down enormously, but there may be room for optimization by having cleaner offset and such. This is why I didn’t add thickness to the surfaces in my script haha. I was trying to do it without plugins as well, which is cumbersome.
I’ve noticed with angular geometry you can handle thousands for surfaces fast by generating everything as meshes first and then converting to Breps at the end if you really need them
I liked Volker’s script too, but the horizontal structure can’t be 3D printed without generating an enormous amount of support material. So I made a bunch of tweaks to elevate the horizontal parts, put some curvature into the column structure, add a circular base, and provide 2 mm thickness for everything:
I’ve never seen anything like that text input to Split (or to anything else), and this is the first time I’ve seen the Match component too. So I just kept all that the same. Below is my tweaked version which is still likely to be changed.
Yes, this was the first time I’ve seen that. I tweaked it by simply removing the long distance values and setting things to use the origin. It was a simple fix.
