Interpolate on surf?
Can a distance be specified with interpolate on srf? Say pick an edge and then move cursor the desired direction type length and it is done.
Other way doing it now is to make crv longer than needed and snap new line to it the length needed. For general construction purposes . Thanks, Mark
Hi Mark- a better workaround might be to make the oversized curve and then use SubCrv - you can specify the desired length in that command - snap the first point to the end to keep and then type in the desired length and Enter.,
You are right. Thanks again. I had not used that command at all. A person should force themself to try a new command each work session just to try and keep up with what this software can do.
