Internal Server Error at compute
I’m currently running an Appserver on my local system. Whenever I attempt to open a custom GH file in the local server using definition.hbs, I encounter an “Internal Server Error at compute” message. All the parameters of the custom Gh file are displayed, but the model is not visible. What steps should I take to resolve this error and open the custom GH file using the Appserver?
I’m assuming you are also running compute locally?
yes i am running this locally
And if you try the other definitions that come with AppServer, do they run as expected?
Yes, the other example file is running.
Are you getting any errors in the console where you are running AppServer? Not the browser console as you have shown.
Also, can you share the definition?
CUBE TEST FOR WEB.gh (8.7 KB)
Please remember the following details:
I have attached the necessary files, including the definition and screenshots of the console, network tab, and local server.
I think you should be using a Context Bake instead of Context Print to display the mesh.
How can I do that? Can you provide more information or some assistance?
What @abdoey96 says is correct. You are only printing out and not returning geometry:
