Hello guys I have this series of lines what I got from brep/brep with end points component the start point in the red circle some points are flipped How can I get all start points in the same side? thanks in advance!
intern points.gh (5.3 KB)Hi @HEEN,
Since your lines are neatly grouped, you can simply get a line point, for instance the center point, for each line and average these points. The new point can then be used as a reference point.
You can now measure the distance between this point and each end point of a line. The end point with the shortest distance to the reference point is going to be the one you are probably looking for.
intern points 2.gh (8.1 KB)
Nice I was thinking on it even I was trying closest to my surface but I had not very clear how to sort it, thank u very much sr!
You’re welcome!
yeey thanks too!
