Interface tweeking
Is is possible to change the order of the objects properties?
I’d like the ‘details’ menu to live at the top since it’s the one most used.
No, it’s not possible to change the order.
:confused: Personally, I would say that this is only used a handful of times per year.
And in case where I would want to access that information, I would use the What command. You can assign this to a key combination for quick access…
Ok, thanks for the help.:relaxed:
