Hello all,
I have been working with a project that is basically a plugin in C# that uses a lot of unmanaged code written in C++. For others that end up hitting this question, you can google the Moose project available in GitHub from @dale.
I have some questions when having this more advanced use case, that I will separate in different topics so that it would stay in the internet for our grandkid’s use.
1- Say my C# plugin calls a C++ function that will return a more complex opennurbs object (ON_Mesh, ON_Brep, etc.). What is the recommended way to instanciate this object in the C++ code?
Should I use a simple new, or should I use one of the functions that are available in the opennurbs_memory.h [ ON_DECL void* onmalloc_forever( size_t ); ON_DECL void* onmalloc( size_t ); ON_DECL void* oncalloc( size_t, size_t ) ];
? If yes, we definately need references to those functions.
2- Now, say that the C++ code needs to free the memory of an opennurbs object. Can we trust that calling the ON_.Destroy() will free the memory of the object and of all of its inner stuff?
In technical terms, is this C++ code the recommended way?
extern "C" __declspec(dllexport) ON_Mesh* CppMeshBuilder()
ON_Mesh* outOnMesh = NULL;
try
int expectedFaces = 1000;
int expectedVertices = 5000;
// ********** QUESTION: Is NEW appropriate?
// Instanciates with NEW
outOnMesh = new ON_Mesh(expectedFaces, expectedVertices, false, false);
// Saves the vertices
for (size_t i = 0; i < expectedVertices; i++)
ON_3fPoint p(x,y,z); // x,y,z placeholders
outOnMesh->m_V.Append(p);
// Saves the faces
for (size_t i = 0; i < expectedFaces; i++)
ON_MeshFace face = ON_MeshFace::UnsetMeshFace;
face.vi[0] = i0; // placeholder
face.vi[1] = i1; // placeholder
face.vi[2] = i2; // placeholder
face.vi[3] = face.vi[2]; // triangular
outOnMesh->m_F.Append(face);
// As seen in the OpenNurbs implementation, this will do all culls together
outOnMesh->CullDegenerates();
catch (const std::exception& ex)
if (outOnMesh != NULL)
// ********** QUESTION: Does destroy suffice?
outOnMesh->Destroy();
return NULL;
@dale Perhaps adding an example like this to the Moose project would make sense?
