Hi there,
whenever I try to specify A3 printing for my working drawings the package instantly crashes… WTF??? It was printing on A3 (several months ago) but I suspect an ‘upgrade’ is to a bad apple… I assume this happens with others?
Please run the Rhino SystemInfo command and return the results.
Hopefully something ovbious will stick out.
Have you been adding your email address and sending in the crash reports?
You instructed to use system info command from Rhino, this is what it states.
I have very limited skills in computer work since gifted severe head injuries 28 years ago, so I am no longer able to easily function with very limited short-term memory.
Hopefully there is something you might suggest?
Thanks in advance
Rhino 7 SR29 2023-4-17 (Rhino 7, 7.29.23107.03002, Git hash:master @ 5f05ef3a2eea3d910c4c2fb79ccc75b413d33ca7)
License type: Commercial, build 2023-04-17
License details: Cloud Zoo
Apple macOS Version 13.2.1 (Build 22D68) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro16,1
Language: en-AU (MacOS default)
AMD Radeon Pro 5500M OpenGL Engine (OpenGL ver:4.1 ATI-4.9.51)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 8176 MB
Graphics: AMD Radeon Pro 5500M
Displays: Color LCD (264dpi 2x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5500M (8 GB)
Color LCD (1792 x 1120 @ 59.00Hz)
USB devices
Apple Inc.: USB3.0 Hub
Western Digital: Elements SE 2622
Realtek: USB 10/100/1000 LAN
Apple Inc.: USB-C Digital AV Multiport Adapter
Generic: USB Audio
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.29.23107.3002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.29.23107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.29.23107.3002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.29.23107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.29.23107.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.29.23107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.29.23107.3002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.29.23107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.29.23107.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.29.23107.3002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.29.23107.1002
In the Rhino 7 pull down menu > Settings (Preferences) > OpenGL, make sure the “GPU Tessellation” option is unchecked.
Any better?
Is already unchecked.
As soon as I tap ‘Paper Sizes’ > ‘Manage Custom Sizes’ it crashes.
It might be a problem with your PLIST.
Mine does not crash.
If it were me, I’d reset the PLIST:
