Instant Crash When Adding Material
just updated to the latest WIP, tried adding a material to a simple cube in rendered mode, instant crash each time https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/1/6/168b02d2c987bada13a5c35fba98c12fc759f605.mov
same thing here as well.
thanks a lot
Akash
Thank you for the report. I have created a YT item [RH-49212] Object Material Properties Page crashes on Mac when adding a new material
https://mcneel.myjetbrains.com/youtrack/issue/RH-49212
This is now fixed and will be available in the next WIP.
Thanks you Max, same problem for me, so could we expect soon the next fixed release? because it is very hard to use it without accessing a library :slight_smile:
Unfortunately the next WIP will be released next week. Currently the + (add button) on the Object Material PropertiesPage crashes. The same control is used also in e.g. Ground Plane Dialog and RenderSettings. They have the same problem with the add button.
However one can add a new material using the Material Editor and then assign the materials using either the Material Editor or the Object Material PropertiesPage. I am sorry for the inconvenience.
Thank you for your quick answer Max
I’ll do this trick until next week :slight_smile:
