Installing a native library so it is visible from ironpython
Thanks for all the replies, you all have been a big help.
Now that i’m nearing completion of my native library, I am looking to make a .rhi installer file to install it. The end goal is to be able to import the dll in ironpython similar to how rhino common is, however I am unsure of how to make it visible to ironpython without giving clr.addreference a direct path to the dll.
Is there any way I can install the DLL so that the clr always adds it as a reference?
Hi @db368,
two possible ways, if it’s for your system only, have you tried to add a new searchpath to the dll directory under:
_EditPythonScript > Tools > Options > Module Search Paths > Add to search path
alternatively, you can install ModuleName.dll with your compiled plugin (rhi). Then use
clr.AddReference(ModuleName)
and it should be usable after importing the namespace. I have a dll which is called like this and the path to it has not been defined as search path like above, so it is not listed in sys.path.
_
c.
