Is-it still possible to install an evaluation version of Rhino 6 ?
The use is to try the connection with ArchiCAD. The link plug-ins are not compatible with Rhino 7 for now.
Regards
Don’t know if this will install as an eval version… maybe.
Hi all - there is no difference between the evaluation versions and “full” versions of Rhino. The only thing that is different is the system behind the downloading where the “evaluation” links will send out an evaluation license key. This will no longer happen for any Rhino 6 downloads.
So that means no, it won’t work for him, as no evaluation key gets sent out?
That is correct, yes.
So I have to wait for ArchiCAD developers to update their rhino/gh plug-ins.
Hope they don’t take 3 months (evaluation period) to make it.
The Rhino 7 Archicad Grasshopper Direct Connection works with Archicad 24. It might need to be re-installed after installing Rhino 7. This has been verified by a couple people including PAZ Academy and Graphisoft’s internal testing.
The ArchiCAD .3DM file importer reads Rhino 6 files. So, at this point Save As… back to Rhino 6 for the files that will need to be in read into ArchiCAD as a 3DM file. Graphisoft is aware of this. This will take a little longer to update to Rhino 7.
