Philip
September 1, 2018, 4:10pm
1
I have the inspectors sidebar with two sections: layers and object properties (layers on top). This reverts back to 2 object properties - I have to manually change the top section to ‘layers’ every time I open Rhino. I’d like to have ‘layers’ stick between sessions - as in V5.
Philip
Erazmataz
(Tim Elkær)
September 2, 2018, 10:24am
2
Is this also the case if you change your Preferences>Themes to have 3 sidebars?
Philip
September 2, 2018, 6:21pm
3
If I have 3 sections I’ll have 3 object properties the next time, so that doesn’t help. I also don’t need 3 sections - 2 is enough for me.
Philip
Philip
September 4, 2018, 8:19pm
4
Known issue…? @dan , @marlin
Philip
John_Brock
(John Brock)
September 4, 2018, 8:52pm
5
Mine does not act like yours.
I have Properties on top and Layers below it.
Did you install Rhino V5.5 SRC?
That’s required so they can share Preferences.
wim
(Wim Dekeyser)
September 5, 2018, 11:47am
6
Hi @Philip ,
I see that here as well - reported as RH-48200 .
John_Brock
(John Brock)
September 5, 2018, 8:07pm
9
I suppose it could be something buggered in your plist.
If it were me, I’d try that first.
robinp
September 6, 2018, 2:47pm
10
I have the same issue. Could you share a file path for where it would be located? @John_Brock
thanks
John_Brock
(John Brock)
September 6, 2018, 2:59pm
12
Sorry, no. I do not know.
Maybe @dan does.
marlin
(Marlin Prowell)
September 6, 2018, 4:14pm
13
This is a bug in how Mac V6 saves the inspector side bar sections between sessions. I’m looking into it.
