InsertEdge - remembering last value used and preview
Hi McNeel
It would be nice, if InsertEdge could remember not just that last used offset type (Ring/Loop) and offset mode (Absolute/Proportional) but also the last value used, eg. a proportional offset value of 0.75. That would make the command much easier to use, as you could avoid typing in the same value over and over again - without having a lot of values macro’ed.
Also, when using proportional values, a preview option would be nice; Unless there’s a way to see which edge is considered 0 and which is considered 1, that I haven’t discovered. I find myself undoing and reverting the numbers (eg from 0.15 to 0.85), since I’m not able to see which edge is considered the starting edge.
TIA, Jakob
bumped to the dev team-
RH-99712 insert edge customer request
