Insert scale question
how to get back to having the question about scale when inserting something in rhino after i put it so as not to ask anymore??
do you have this / or window-equivalent dialog ?
are you typing the command _insert ?
check the “Prompt” checkbox.
are you using a button in a toolbar and have changed the underlying macro ?
maybe give a bit more info, so others can repeat your workflow.
kind regards -tom
The Rhino “ResetMessageBoxes” command will globally reset them too:
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/resetmessageboxes.htm
