Insert Revit Family inside family by coordinates
Hi guys,
Is there a way I can insert a revit family inside the project by coordinates (xyz) given that
it used the project coordinate system.
thanks
Revit internal coordinates never change and correspond with Rhino XYZ, transform a Rhino coordinate by the project coordinate system to place a Revit Family at the desired location.
Similar to this workflow Rhino.Inside®.Revit
Hi Japhy,
I am trying to insert my 2d annotation using the coordinates input, but no luck at the moment? cheers
Any help guys? Thanks
Please check the below, is working fine for me, if it doesn’t solve it for you… maybe you can share a small sample to replicate the issue
Thank you Mohamed, I got this warning - 1. The input P lies outside of Revit design limits. Design limits are ±16,093,440 mm around the origin.
Thanks
There is a limit.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-3F79BF5A-F051-49F3-951E-D3E86F51BECC
Thank you guys for the assistance, kind regards.
