Insert pdf bug
I got a 2D drawing as pdf and inserted it to a document and it has two issues:
1: It doesn’t show up in the layer manager
2: every time I open the file I get this dialog:
Hi Jorgen- I see that, thanks- the scaling dialog is expected, if not by you, at least by the current workings, as far as I can tell, since there are no units - same happens on inserting a dwg file. But of course this raises the question- should (and can) Rhino keep track of this automatically… seems like it should.
http://mcneel.myjetbrains.com/youtrack/issue/RH-29126
http://mcneel.myjetbrains.com/youtrack/issue/RH-29127
? :slight_smile:
You should know that I am gold medal material in the fat-finger Olympics…
-PG
