This is the bug that I’ve noticed recently.
Hi - Could you share that file, please?
I think you’ll need to use InsertPoint to get the edge where you want it across that N sided face. It may still need additional clean up or edge adjustment depending on the smooth shading too.
Sure, what’s the email I should send it to?
Yes, Insert Point does the job in this particular case. Thanks Brian. I just thought that Insert Edge should also work in a similar fashion if the faces are not similar like in the example.
If it’s not something that you can share here, please use Rhino - Upload to Support
Make sure to add the url to this thread in the comments field!
Thanks, just sent it through!
Got it! Thanks,
