Insert Block shaded preview?
Hi RMA,
Would it be possible to have optional ‘insert block’ mode that shows the interactive block as shaded or just uses the current view display mode, instead of always wireframe? On complex models with many overlapping elements very often it is confusing where the wireframe block lands, and needs to be moved as soon as it is inserted. So like in Move, Copy etc, shaded interactive preview would be great as an option. Either a global setting in Options, or a switch in command-line options of _-InsertBlock and _InstertBlock dialog box.
Thank you,
Jarek
