When I place the block, the ‘R’, without rotation at the point all is good.
As soon as I use the rotation option from the _insert dialog the block is rotated around some other place.
Hi Charles- so far this seems OK here- the insertion point is right at the ‘R’ and if I ask for rotation it seems to rotate around this point… It looks like no rotation is visually rotated to 45 degrees, correct?
OK, I see it, thanks, I thought you were inserting the entire file you sent. Looks weird to me indeed… still poking.
It looks like it is rotating around the World 0,0,0, relative to the location you pick for insertion. That is, if you export the block, the resulting file’s World origin is located relative to the ‘R’ at what looks like the rotation point when you insert the block… very strange, I do not see a good reason for this yet, so I assume it is a bug.
