there is a little problem with the Block insert dialog. The filechooser is missing an ui element. This is just a display problem, it works as expected.
Hi Jan,
Are you talking about the drop down list next to file? Do you think it needs an embossed look?
Yes, that’s what I mean and every Mac user is used to it as this is the ui element to be used. You use it at other dialogs too.
got it… filed the UI tweak
