I expeirence insanely slow times for creating a 2D drawing.
In general Rhino seems to have slowed down tremendously since the first beta’s 3-4 years ago…
Hi Jan- what is the file tolerance set to? Is it comparable to the previous tests where things worked faster? You might try backing the tolerance out by 10X and see if you get acceptable results.
absolute tolerance is currently at 0.001 which is standard right?
Yes it is… in general .001 should work well, I just wanted to make sure you are not comparing results for similar files at different tolerance, since this does affect the speed. Pehaps you can post an example file or send to tech@mcnell.com via www.rhino3d.com/upload
I set it on 0.01 and it worked like a charm…
