Insanely slow file editing
I have a file which is ca. 50MB, first created in V7, then work was carried in V9. The speed of work was normal but, suddenly, it dropped down and every action takes seconds to perform.
Purging is not helping but audit shows problems which I don’t know how to deal with.
When saved as V7, file works as nothing is happening and audit shows no errors.
Audit summary V9:
There are so many errors in this file that I can’t even attach the summary due too many digits but, basically, it goes like this, but for long.
Document Manifest:
Texture Mapping: 147 active, 1 system.
RenderMaterial[195] name missing from document manifest.
Material: Error: differences between model table[195] and manifest information.
RenderMaterial[196] name missing from document manifest.
Material: Error: differences between model table[196] and manifest information.
RenderMaterial[197] name missing from document manifest.
Material: Error: differences between model table[197] and manifest information.
Audit summary V7:
Summary
Document Manifest:
Material: 861 active, 2 system.
Line Pattern: 2 active, 3 system.
Layer: 28 active, 1 system.
Group: 475 active.
TextStyle: none.
Annotation Style: 2 active, 12 system.
Light: none.
Hatch Pattern: 2 active, 9 system.
Block: none.
Model Geometry: 28919 active.
Total: 30436 model components. 28 system components.
Audit Summary:
Table tally:
28 layers
2 annotation styles
0 fonts
2 linetypes
861 rendering materials
Object tally:
27360 normal objects
0 locked objects
1559 hidden objects
1 deleted objects (in undo buffer)
0 block definition objects
0 reference normal objects
0 reference locked objects
0 reference hidden objects
0 reference block definition objects
No errors.
I will send the file to tech.
File saved as V7 and opened back in V9 (9-7-9) is slow again, and here is the audit of the imported version:
Summary
Document Manifest:
Group: 474 active.
TextStyle: none.
Annotation Style: 2 active, 13 system.
Light: none.
Block: none.
Error: 30435 model components (0 deleted). 29 system components. 30466 manifest items
Audit Summary:
0 object errors detected.
0 linetype table errors detected.
0 layer table errors detected.
0 block table errors detected.
0 font table errors detected.
0 annotation style table errors detected.
Table tally:
28 layers
2 annotation styles
0 fonts
2 linetypes
Object tally:
0 unreferenced objects
0 locked objects
1559 hidden objects
Audit found problems.
Thanks for reporting. The fix should come with the next update.
