Inquire how to delete mesh points in Rhino 8
lease tell me how to delete mesh points in Rhino 8. In Rhino 7, I activated the mesh point from the mesh to f10, selected the point, and deleted it using the del key, but it is not deleted in Rhino 8. Is it a problem with the option?
Hi -
It looks like that was changed in Rhino 8. When you delete a vertex, a new ngon face is created. If you want to delete a mesh face, sub-object select the mesh face and use the delete key. You can sub-object select either by holding Ctrl+Shift, or by using the SelectionFilterFaces command to activate the selection filter.
