Input of "seed" values - an infinite number?
Just wanted to know if there is a limit to the input seed values before the sequence starts repeating in components like Random or Populate… I see that negative values are simply flipped to positive, but is there a point in the positive direction after which it repeats the pattern?
Thanks, --Mitch
I don’t know to be honest. It’s just the seed value that gets pumped in to System.Random. Based on the MSDN docs it seems there is no point at which the seed repeats, except that negative values are indeed the same as positive values.
OK, thanks David! --Mitch
