Injection Molding Question
Okay, so my client asked for the absolutely minimal number of plastic parts assembly. What you see is my initial sketch of one of those assembly parts. Instead of two I’m attempting at getting it done in one. It’s for styrene injection molding. Aluminum molds I suspect. Two part mold. I don’t have that much experience with advanced injection molding so it got me wondering if this configuration is actually doable…? Dimensions are for the real size. Draft angle analysis is set to between 1.5 and -1.5. It is a very small piece. Thank you.
Injection Molding.3dm (5.2 MB)
I don’t have any experience with making tiny plastic parts, but it looks doable to me.
You have established the parting so go ahead and make the two part mold and present that model of that to the shop that will make the tooling. They will tell you if that will work. The tool maker would design the gating so you don’t have to worry about that.
One thing that stands out, is that the mold will have some knife edges in the area circled in green in the pic below. That area may require some slight changes to make it work.
Does injection molding have certain rules to go by? Maybe this can help when modelling for that manufacturing method
For example i know a slight draft angle is needed so the part can come out smoothly from the mold
I come from 3d printing side i know there is alot of rules for the different techniques when modelling for them, i believe this can have similar traits.
I would recommend checking the part with some specific mold flow analysis software to see weld lines, sink areas and warp effect. This could give you some hints for doing some local modifications.
Unfortunately, there is no Rhino plugin for mold flow analysis. Not I aware of. It’s all about separate software, which is pretty expensive. But there are services doing such tasks for users.
You could upload your part to Protolabs website they have an injection mold checker and even can send out a model to you in the mail with dos and don’ts of injection molding procedures. There are number of considerations.
RM
Injection Molding Services for Custom Parts - Protolabs
Many thanks for all your comments. Most appreciated.
There seems to be no immediate red flags. Which is good. Those sharp edges are also my concern. Will have to play with it a little more and see if it can be mitigated to more acceptable levels.
My situation is a little bit different. I don’t have direct contact with the shop. I do the 3d work and then transfer all files to my client who is dealing with the tooling shop. It worked fine couple of times before. Those projects were pretty clean and there were no major issues. This time a bit more complicated. But if they find issues with the parts then the shop can fix it on their own, except for some extra cost, obviously.
If this was a North American job I wouldn’t mind talking to Protolabs but at this point it’s not my call.
As for the mold flow analysis software, I do this type of projects too sporadically for getting invested in more expensive software. But will have to look around for other options as I’ve never considered it until now.
The real issue is that this part is very small - about the size of a grain of rice. The size alone is going to determine what is doable.
This is what a cross section of the the mold in that spot will look like as it is now:
That might be changed to something like this to get rid of those knife edges.
Its easiest to model the mold and make changes to the mold and then extract the changes back to the part.
This is exactly what I’m trying to fix now. Probably the easier solution would be to completely eliminate the see-through space with solid fill. It might end up there eventually after the molding shop sees the files. But for now I am just adding a bit of thickness to parting edges and let them decide on the final cut.
Oh and thanks for the visualization. It’s very useful point of view which I regularly ignore relying mostly on draft angle analysis
