the infoline above the commandline is not visible how can this happen and how can i solve it.
Hi -
Both the menu and the title bar are above the command line in the default set-up.
You can turn these on and off from the Rhino Options > Appearance page.
Hi Wim,
thanks for help.
Unfortunatly it does not solve the problem in my case.
With “infoline” i mean the text output field if a command is executed.
For example if i write Distance in the command prompt the value is printed in the infoline but this infoline (text area above the command prompt) is not there where it should be.
Thanks for your help.
Hi @flokart
Just grab the grey bottom line of the command prompt and drag it down to expose the number of lines of the command history you wish to see.
