Hi all,
I am trying to inflate mini-greenhouses and I have created a script to work but only on the z-axis, How could I do this while applying it to surface normals? The load force vector will not accept normals or amplitude,
Thanks
Hi all,
Thanks
Thanks, Martin!
I have been trying to replace the load with that, but not sure if that’s all I need to change?
forum.gh (95.9 KB)
I don’t have a few of your components so I took a part of your definition and added a simple mesh box with open bottom side as input. Hover your mouse over the Pressure component to read what the component does. It says: A force normal to each triangle, and proportional to its area.
If the mesh just pops, usually the strength inputs are off.
inflate_mesh.gh (28.3 KB)
This is great thank you Martin!
