Hi there,
I would like to ask, if there is an infinite surface method in Rhino V5 by using projection to the surface. It often happens that the target is shorter then the result requires to be .
Hi there,
Hi @onrender,
No, Rhino does not have an infinite surface object. Can you provide more details on what you are trying to do? Sample code can often help too.
– Dale
Hi Dale,
I mean, for example a pitched roof of a house and I want to attach a wall to the roof surface by projection to create a dormer.
It works, when the wall top and bottom side in-between the roof’s eaves and ridge level but what if a part of the wall is located below the eaves.
I will scale the surface…
Sounds like a plan.
