Increasing distance extruded along a single curve
Hi all,
I’m trying to generate a waffle structure with adaptive heights based on attractor points.
I’m trying to generate the lower section of these beams to have taller extrusions, can’t get it to have smooth transitions along the curve. only change the height of the whole curve
This is the waffle structure script I have that works but has no attractors.
Waffle script.gh (20.8 KB)
I would appreciate any help, thanks!
please internalize your starting Surface and repost the GH file
here is the GH with internalized surface
Waffle script_IT.gh (115.3 KB)
I cannot open your script, it hangs grasshopper & rhino.
hangs for me for a few mins aswell, heres the file with the final booleans disabled and less divisions. should be able to open fine now
Waffle script_simple.gh (120.3 KB)
I’m not quite sure I understand the issue, Have you tried doing an offset of some type? It would keep the distance consistent.
sorry i probably havnt described it the best
i am trying to have the beams be larger in the z direction as the get closer to the blue point in the image above.
this is the project im trying to mimic
you can see the beams are larger towards the points closest to the ground
Something like that?
i belive exactly like that
looking at your script now i think i was so close
Thankyou!
