Inconsistent UV transformations between the Viewer API and AR instances
Hello. I hope you can shed some light on this.
My file includes several instances of the TransformUV component. I merge and compound transformations, then feed them into the Transform input of the TransformUV component.
When I view the model using my implementation with the Viewer API, the transforms appear as mirrored compared to what the AR instance displays. Any ideas?
Thanks
Viewer v 3.2.4
ShapeDiver Plugin v 1.17.1
I just did some tests and could not reproduce this issue. Could you share a minimal definition that helps reproduce it (different visualization in the ShapeDiver model view page and in AR)? I would suggest you first upgrade to the latest version of the plugin (1.21.0).
