Inconsistent Options Lifetime / multistep commands
(following the "one aspect = one topic forum rule …)
the general issue i am talking about is: how long can a user access options, if a command has multiple steps / stages.
my expectation: an option should survive as long as it is valid
_matchSrf
not sure if i am the only one, but forgetting to click “mulitple matches” at the beginning of _matchSrf dialog fooled me a lot.
_line 50 _bothsides=_yes <45
this is another one: if you want to draw a line with 100 mm from the midpoint (bothsides) with snapping 45 degree - order matters.
if you input length first _line “50” and add bothsides=yes your first input (50 for length) is lost.
if you input <45 first bothside=yes will reset angular snapping.
there are more commands where options do not survive, even if they are still valid input - please add them to this topic.
but also consider, that some commands have this kind of hierarchy, because they following some hidden decision diagram that is defined by geometric constraints.
_arc
is a great example for this category.
would like to see all this consistency aspects for one of the focus of Rhino Version 10. And quite sure this is something where AI can shine and help a lot. (also in accessing old code base)
see you in barcelona on wednesday - tom
Here is another command with similar inconsistency with remembering options: Inconsistent UI - #7 by Stefano_Menci
yep - that s another aspect:
commands that do not remember options / choices from one run to the next run.
this topic is more about a single run of a command with multiple steps, where an option only pops up once, but would make sense to survive several steps of the command.
