When I enter Turntable then I get a slider allowing adjustment of animation speed.
What unit is that speed in?
Background: I want to get a feeling how a certain object would look on a hardware turntable rotating at 0.5 rpm. For that I do not need to render the animation.
I’m not sure but @JohnM may know. I bet a setting of 5 would be close to a product display like this. If you can find a video of it running that would also give you a speed to match visually.
Turntable speed is a value between -100 and 100 that is used in a calculation that determines how much the view is rotated (angle) every time the scene is redrawn. Not sure this helps…
This is going to depend on the complexity of the scene and your graphics card capacity. In my experience, every model will be different and complex models will slow way down…
