Improper argument - when returning to the Rhino window
This dialog quite frequently (2-3 / day) appears when one returns to Rhino (after visiting another application).
At the moment I have no clue what is causing it, but it is not necessarily leaving an ongoing command and then returning.
Will try to pinpoint.
Please run the Rhino command _SystemInfo and post the complete result here in a reply.
hey,
i have this persistent issue. as well as my computer GPU is skyrocketing.
idk what to do, could you provide some help?
Rhino 8 SR7 2024-5-17 (Rhino 8, 8.7.24138.15431, Git hash:master @ 03702f889bdef32626af4bca510b5e8a85666d38)
License type: Evaluation, build 2024-05-17
License details: Cloud Zoo
Expires on: 2024-07-29
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [91% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 10-3-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.99
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-1-2024
Driver Version: 32.0.15.5599
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.24138.1238
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24138.15431
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.7.24138.15431
Interesting, I have seen this error pretty much only on AMD GPU. Anyway, does it persist when disabling the Enscape plug-in (and restart Rhino after disabling).
i basically disabled almost all plugnis except enscape, because i needed enscape, and it works fine. but now the model seems to heavy to run enscape smh.
so my computer specs should be fine?
